[OpenLayers-Users] Cluster Strategy and Google Layer
Eric Lemoine
eric.c2c at gmail.com
Fri Oct 31 12:57:45 EDT 2008
Hi. The EPSG:900913 projection should be set in the map options. In
this way your vector layer is also a 900913-projected layer. If your
vector points are expressed in 4326 you have to have them re-projected
before the're added to the layer. Eric
2008/10/31, Salvaro <asufsc at gmail.com>:
> I'm using a Vector Layer with Cluster Strategy (and Fixed) overlaying a WMS
> (EPSG:4326) and a Google Layer (EPSG:900913).
> In the WMS layer the strategy works perfectly. But in Google Layer, the
> layer apparently ignores the Strategy.
> Testing I saw a "strange" thing, when I use the points in EPSG:4326
> coordinates in the Google Layer and all points are in the centre of the map,
> looking the opacity is possible to see the points being "clustered". But
> when I try to reproject them or just set different coordinates of the google
> projection, the layer ignores the cluster.
> The points with correct projection:
> http://img225.imageshack.us/my.php?image=correctprojectionyx8.jpg
> And with the incorrect projection:
> http://img404.imageshack.us/my.php?image=wrongprojectiontk6.jpg
> http://img505.imageshack.us/my.php?image=wrongprojection2ty8.jpg
> I'm using in the Map these attributes: numZoomLevels=19,
> displayProjection=EPSG:4326 and the controls.
> In the layer: type=GMAPS, projection=EPSG:900913, maxExtent=-20037508.34,
> -20037508.34, 20037508.34, 20037508.34, units=m, maxResolution=156543.0339F
> and sphericalMercator=true.
> The points are being added using addFeatures.
> Anyone have an idea about what it can be and how can I do the cluster works
> with the Google Layer?
> Thanks!
> http://n2.nabble.com/Cluster-Strategy-and-Google-Layer-tp1402961p1402961.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
