[OpenLayers-Users] Vector features don't display at level 0
Alexandre Dube
adube at mapgears.com
Thu Sep 4 09:31:30 EDT 2008
Alan,
Ok, I'll use the trunk only to test some strange behaviors/issues/bugs
then, not as my main application.
Thanks,
Alexandre
aboudreault at mapgears.com wrote:
> (sorry for the double post)
> Hi Alexandre,
> In my opinion, trunk is trunk. :) It can still have a lot of changes (and bugs in your application) until the next release. I suggest you to make your application works with the current release and update it to OL 2.7 when it will be released (IF NEEDED).
> Regards,
> Alan
> Alexandre Dube wrote:
>> Hi Eric,
>> I had never actually used the trunk up to now. I've just tried it and
>> it works fine, but I have other bugs that appeared ( but I'll try to fix
>> them before complaining :) ... )
>> Anyway, should I use the trunk instead of my own OL I downloaded ? Or
>> should I wait for the 2.7 release to see if my fun issue will disappear ?
>> Many thanks,
>> Alexandre
>> Eric Lemoine wrote:
>>> Hi Alexandre. This is a fun issue :) Do you use OpenLayers trunk? Eric
>>> 2008/9/3, Alexandre Dube <adube at mapgears.com>:
>>>> Hi everybody,
>>>> I have a WFS layer that displays features on different zoom levels.
>>>> When I initialize the zoom level to anything but 0, features are
>>>> displayed. If I then go back to level 0, features are displayed.
>>>> But, when I start at level 0, features are not displayed. I then zoom
>>>> to level 1 and here they are. Back to 0 they're here again. Also, if I
>>>> start at level 0 ( features not here ), and unselect the layer in the
>>>> layerswitcher and reselect it, features appear.
>>>> When starting at level 0, the features array contain features. The
>>>> layer is inRange and is Visible so it should show its features ?
>>>> Any hint ?
>>>> Alexandre Dubé
>>>> Mapgears
>>>> www.mapgears.com
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
