[OpenLayers-Users] openlayers does not show shapefile
Huseyin Akyol
huseyin.akyol at gmail.com
Thu Sep 4 18:25:20 EDT 2008
i guess the problem is caused by the name of your map file. Somehow mapserver
can't read the first letter of mapfile names beginning with letter "t". You
can check your apache logs, in access.log file, you will see the mapfile in
query string doesn't have its first letter. Change the name of your mapfile
and try again.
Best Regards
Huseyin
George.Muammar wrote:
> Hi,
> I can't get through to your server but I suspect the mapfile is not
> configured correctly. I don't think shp2img is a valid test, the
> shapefile may not show on your map because of an extent problem.
> If you see any PNG from the WMS server it means that OL is working ok.
> The problem is with the WMS.
> Try this in Firefox, Tools -> View Page Info, Click on Media Tab and
> look at the properties of the images listed there.
> Hope that helps.
> George
> FCampos wrote:
>> Hi,
>> i´m haviing trouble to show a simple shapefile frmo a wms server
>> (mapserver).
>> Here is the mapfile
>> http://www.nabble.com/file/p18867858/test.map test.map
>> if i make shp2img -m test.map -o test.png -all_debug 10 the image is
>> made,
>> so it´s not from mapserver.
>> the openlayers code is:
>> map = new OpenLayers.Map( 'map' );
>> var layer = new OpenLayers.Layer.WMS( "SHAPEFILE",
>> "http://172.18.210.67:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/wmssrvrefer/test.map&service=WMS",
>> {'layers': 'Cont_Freg_CAOP2008_HG73' , 'format':'image/png'});
>> map.addLayer(layer);
>> the image shows only the background.
>> what´s wrong ?
>> Thanks.
> Proxy scanned this message.... no virus found!
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.5.12/1597 - Release Date: 8/7/2008
> 5:54 AM
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/openlayers-does-not-show-shapefile-tp18867858p19321275.html
