[OpenLayers-Users] Switch to google layer set diff center then at other layers
Mikesamar tech at reumer.net
Sun Sep 7 12:24:35 EDT 2008
I think that Yahoo has the same problem as Google. Sometimes the tile of
Yahoo are loaded in the left upper hand corner.
If I resize the window then the tiles loads completly.
Mikesamar wrote:
> Is somebody of openlayers also working on this problem?
> I've debugged it and it looks like the onMapResize is only called once and
> not for all layers with google maps (I've three). Is there for each google
> layer a seperated object?
> If I remove the checkResize in onMapResize then the first google map is
> showing allright. But when I resize the window then more layers are not
> allright, only the current showing is allright.
View this message in context: http://www.nabble.com/Switch-to-google-layer-set-diff-center-then-at-other-layers-tp19277367p19359752.html
