[OpenLayers-Users] center crosshairs?
geoman
csabbey at gmail.com
Tue Sep 9 14:21:16 EDT 2008
Hello,
I am trying to add a icon that is fixed at the center of a map, to show
where the center is when people are zooming. I didn't see a way to add an
icon to a map directly, and it looks like if I put the icon in a marker and
then add that to a layer on the map then the icon will move with the map.
My solution was to add the icon through the DOM (using Prototype:)
var centerIcon = new Element("img");
centerIcon.src = "img/center5.gif";
centerIcon.id = "mapCenter";
centerImg.setStyle({
left: ((document.viewport.getWidth() / 2) - (centerImg.getWidth() / 2))
+ 'px',
top: ((document.viewport.getHeight() / 2) - (centerImg.getHeight() /
2)) + 'px'
$('map_OpenLayers_ViewPort').insert(centerIcon);
Here is the styling I used for this element:
img#mapCenter {
position: absolute;
z-index: 10000;
Is there a way to do this using the OpenLayers API? If not, can you offer
any solutions with a couple major problems I see with the above approach:
1. The icon isn't always at the center of the map; it is always close, but
when I zoom in I can tell it is slightly high and to the left. I'm not sure
why it is usually dead-center and sometimes off-center.
2. Markers under the icon no longer receive mouse events. I tried to set the
z-index of the icon so it would be under my marker layer, but my
map_OpenLayers_Container has a z-index of 749 and my marker layer has a
z-index of 350, and I can't set the z-index both above 749 (so the icon is
visible over the map tiles) and below 350 (so the markers will receive input
events).
Thanks in advance,
Craig
View this message in context: http://www.nabble.com/center-crosshairs--tp19398206p19398206.html
