[OpenLayers-Users] center crosshairs?
Arnd Wippermann arnd.wippermann at web.de
Tue Sep 9 17:30:02 EDT 2008
To get a visible center on the map, i create a vector layer with a
horizontal and a vertical line updated through
map.events.register('move',...).
You can test it with the following code. Run it in the firebug console.
Arnd Wippermann
map.events.register('move', map, function()
    point = map.getCenter();
    setCenterGrid(map, point.lon, point.lat);
function setCenterGridLayer(mapObj, strokeWidth, strokeColor)
    var flag=false;
    //Look for layer Fadenkreuz
    for(var i=0;i<mapObj.layers;i++)
        if(mapObj.layers[i].Fadenkreuz)
            flag=true;
    //layer Fadenkreuz not there, then create
    if(flag==false)
        var vector = new OpenLayers.Layer.Vector("Fadenkreuz");
        vector.styleMap = new OpenLayers.StyleMap({'default':{'strokeWidth':
strokeWidth, 'strokeColor': strokeColor}});
        vector.Fadenkreuz = true;
        map.addLayer(vector);
function setCenterGrid(mapObj, x, y)
    var idx=-1;
    //get index for layer Fadenkreuz
    for(var i=0;i<mapObj.layers.length;i++)
            idx=i;
    if(idx==-1)
        return;
    mapObj.layers[idx].destroyFeatures();
    var pointAw = new OpenLayers.Geometry.Point(mapObj.getExtent().left, y);
    var pointBw = new OpenLayers.Geometry.Point(mapObj.getExtent().right,
y);
    var pointAs = new OpenLayers.Geometry.Point(x, mapObj.getExtent().top);
    var pointBs = new OpenLayers.Geometry.Point(x,
mapObj.getExtent().bottom);
    var lineFeatureW = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.LineString([pointAw, pointBw]),null,null);
    var lineFeatureS = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.LineString([pointAs, pointBs]),null,null);
    mapObj.layers[idx].addFeatures([lineFeatureW, lineFeatureS]);
setCenterGridLayer(map, 1, "white");
