[OpenLayers-Users] How do I get my polygon coordinates?
    Bijoy
    bijoya at rediff.co.in
    Thu Sep 11 05:49:04 EDT 2008
Guys!
I need some hint on getting the polygon coordinates... I have been trying
for hours.. but, no help. Can we get the coordinates of dynamically created
polygon.
I am able to get the done status of drawing polygon, but cannot get the
coordinates. This is how i am trying to do...
----- code ----
var polycontrol;
function init(){
	map = new OpenLayers.Map('map', {'maxResolution': 'auto'});
	layer = new OpenLayers.Layer.WMS("OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
	vectors = new OpenLayers.Layer.Vector("Vector Layer");
	map.addLayers([layer, vectors]);
	map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
	map.setOptions({restrictedExtent:new OpenLayers.Bounds(-180, -90, 180,
90)});
	map.addControl(new OpenLayers.Control.MousePosition());
function addPolygon(){
	polycontrol = new OpenLayers.Control.DrawFeature(vectors,
OpenLayers.Handler.Polygon, {'featureAdded': check});
	map.addControl(polycontrol);
	polycontrol.activate();
function check(obj){
	var geometry = new OpenLayers.Geometry.Polygon();
	alert(geometry.toString());                    <================ Need
Polygon Co-ordinates Here.
	alert(geometry.getBounds());
	polycontrol.deactivate();
---- code ends ----
But, inside the check function, I get results like "POLYGON()" on
geometry.toString()...
Can anyone please help?
<BIJOY>
Bijoy wrote:
> I got this from another mail
> OpenLayers.Handler.Polygon, {'featureAdded': YourFunction});
> But, I am still stuck with getting the co-ordinates.
> <BIJOY>
> Bijoy wrote:
>> Thanks Kumar...
>> But, am already using Polygon Handler in the Drawfeature control
>> constructure. How do i combine both the constructor to get the "done"
>> command.
>> Can anyone help me, if you have any idea...
>> <BIJOY>
>> Kumar Mettu wrote:
>>> Bijoy,
>>>   Have you tried using Polygon Handler Constructor?
>>> http://dev.openlayers.org/releases/OpenLayers-2.6/doc/apidocs/files/OpenLayers/Handler/Polygon-js.html
>>>   This should answer your question.
>>> Kumar.
>>> Bijoy wrote:
>>>> Thanks for the reply.. Salvaro,
>>>> Can we call a function 'oncomplete' or 'done' of drawing a polygon.
>>>> And, then may be I want to get the polygon coordinates. User completes
>>>> the polygon drawing by doubleclicking.
>>>> I am using the below URL as example:
>>>> http://openlayers.org/dev/examples/select-feature.html
>>>> <BIJOY>
>>>> Salvaro wrote:
>>>>> geometry.getBounds().getCenterLonlat() ?
>>>>> Salvaro.
>>>>> Bijoy wrote:
>>>>>> Hey,
>>>>>> I am drawing a polygon using the handler as shown below:
>>>>>> OpenLayers.Handler.Polygon);
>>>>>> Now, how do I get polygon coordinates when I finish drawing the
>>>>>> polygon?
>>>>>> View this message in context:
>>>>>> http://www.nabble.com/How-do-I-get-my-polygon-coordinates--tp19413142p19413142.html
>>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> Users mailing list
>>>>>> Users at openlayers.org
>>>>>> http://openlayers.org/mailman/listinfo/users
>>>>> http://n2.nabble.com/How-do-I-get-my-polygon-coordinates--tp1079900p1079911.html
>>>>> Users mailing list
View this message in context: http://www.nabble.com/How-do-I-get-my-polygon-coordinates--tp19413142p19431317.html
