[OpenLayers-Users] Jumping map while panning in Internet
Explorer
Erik Uzureau
euzuro at gmail.com
Tue Sep 16 02:10:52 EDT 2008
Things that come to mind are css attributes on the containing DOMElements
like 'margin', 'padding', etc.
I would suggest trying with the latest RC from the 2.7 branch. We are within a
couple of weeks of doing the 2.7 final release, and it contains a fix for the
aforementioned 'container-css' problem.
http://openlayers.org/api/2.7-rc2/OpenLayers.js
e
On Mon, Sep 15, 2008 at 10:42 PM, Linda_Rawson <linda.rawson at gmail.com> wrote:
> Did you find a solution to this problem?
> Thanks,
> Linda Rawson
> Stephen Lee-8 wrote:
>> Hi there,
>> I need help solving this problem I had while panning the map in Internet
>> Explorer, the nature of the problem is this:
>> I have a webpage that contain the map div within a Tabcontrol from ASP
>> Ajax
>> Toolkit, when view in Firefox, everything went well, but under Internet
>> Explorer, sometimes (especially when I refresh the page), the Openlayers
>> start to encounter problem. The nature of the problem is that somehow
>> sometimes, the map is not loaded properly, causing the Pan function to
>> misbehave: when panning, it pan to invalid places. I have hosted the
>> webpage
>> at this address: http://www.tmavl.com/test.aspx. Currently the only
>> solution
>> I had is to place the map div outside the TabControl, can anyone help me
>> to
>> identify the cause of this? I have attached the source code in this email.
>> If you can't simulate the error on first try, try refreshing the test.aspx
>> a
>> few times, gmail does not allow me to attached the test.aspx.vb file, but
>> its empty anyway.
>> My test environment:
>> - Openlayers 2.6
>> - IE 7
>> - Firefox 3.01
>> - ASP.Net
>> Thanks in advance, I'm currently really at the end of my wits, appreciate
>> any suggestion or help.
>> Best regards,
>> Stephen
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> View this message in context: http://www.nabble.com/Jumping-map-while-panning-in-Internet-Explorer-tp19261638p19504811.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
