[OpenLayers-Users] Slow performance when zooming in to large vector object in IE
Zer hcan at hotmail.com
Wed Sep 17 16:51:48 EDT 2008
Hi Andreas,
Unfortunately, I can not provide a public link for the moment, I could
create a code snippet and a GML file if that could help.
I am using 2.6 and in this case is it just one (1) vector! I will give 2.7 a
try asap in report back.
-Z
Andreas Hocevar-3 wrote:
> Can you provide a public accessible demo?
> Also, it would be interesting to know which version of OpenLayers you
> are using. Version 2.7 (currently at release candidate 2) has several
> improvements here, compared to 2.6.
> If you can render your vectors on a server, then do that. If you need
> mouseover effects and other interaction on the map, it is probably ok to
> render vectors on the client. Also, as a rule of thumb, if the number of
> features/vertices goes up to the 1000s, things are likely to get slow,
> especially in IE.
> Regards,
> Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Slow-performance-when-zooming-in-to-large-vector-object-in-IE-tp19540424p19540867.html
