[OpenLayers-Users] VectorLayer disappears at zoom 17 (and
lesser).
Salvaro
asufsc at gmail.com
Thu Sep 18 10:15:52 EDT 2008
I've one problem to do this, as the another time I'm programming direct in
Java with GWT+openlayers, and haven't a way to put it in a server with a
legible code.
I guess it should be a problem when calculates/uses the resolution/scale (is
possible to configure it manually?).
The fact of the map was in sphericalMercator or not (vl only appear when
sM=false) have any influence in it?
I'll try to recreate the problem directly in JavaScript.
Thanks,
Salvaro.
Christopher Schmidt-2 wrote:
> On Thu, Sep 18, 2008 at 06:15:34AM -0700, Salvaro wrote:
>> I did it (upgraded to the OL 2.7).
>> But the problem with vectorLayer continues.
>> It's still appearing with WMS and in the Google Maps with
>> sphericalMecator=false (with the known problem when pan), but when I set
>> sphericalMercator=true, the vectorLayer disappears and only appears on
>> the
>> zoom level 17 (I'm using 19 levels)..
> Please create/publish/share an HTML example that demonstrates this.
> -- Chris
>> Thanks,
>> Salvaro.
>> Andreas Hocevar-2 wrote:
>> > Salvaro wrote:
>> >> Andreas,
>> >> Is this patch compatible with the OL 2.6?
>> > It won't apply to VML.js from 2.6, but if you walk through the hunks
>> and
>> > apply them manually, it will work.
>> > Note, however, that there were many other vector rendering improvements
>> > between 2.6 and 2.7, so you might want to upgrade.
>> > Regards,
>> > Andreas.
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> View this message in context:
>> http://n2.nabble.com/VectorLayer-disappears-at-zoom-17-%28and-lesser%29.-tp1079719p1098120.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Christopher Schmidt
> MetaCarta
> Users mailing list
View this message in context: http://n2.nabble.com/VectorLayer-disappears-at-zoom-17-%28and-lesser%29.-tp1079719p1098257.html
