[OpenLayers-Users] Accuracy of OpenLayers at scales less than 1:15000
Jean-Marc Strydom j-ms at souwest.co.za
Fri Sep 19 07:40:29 EDT 2008
Hi Arndt
That did the trick !  Much more accurate - more accurate than what we need,
although positioning does go slightly out at very large scales (ie. down to
1:200) but the key thing is that the mouse position is correctly reflected
in the displayed cords and that the mouse event picks up the correct land
parcel.  Thanks ever so much.  BTW, why would those parameters affect the
map ?
Regards
Jean-Marc
----- Original Message -----
From: "Arnd Wippermann" <arnd.wippermann at web.de>
To: "'j-ms'" <j-ms at souwest.co.za>
Cc: <users at openlayers.org>
Sent: Friday, September 19, 2008 12:46 PM
Subject: AW: [OpenLayers-Users] Accuracy of OpenLayers at scales less than
1:15000
> Hi,
> try it without these params, then it should work.
> width: '800',
> height: '400',
> tiled: 'true',
> tilesOrigin : "27.666619,-32.907249"
> layer_Selected = new OpenLayers.Layer.WMS(
>    "Selected", "/geoserver/wms",
>        CQL_FILTER: "(sgnumber = 'c04000060000001500000')",
>        srs: 'EPSG:4326',
>        styles: 'LandParcel_Selected',
>        layers: '_view_gis_landparcel_full',
>        format: 'image/png',
>        transparent: true
>    {buffer: 0, 'opacity': 0.4, 'isBaseLayer': false}
> map.addLayer(layer_Selected);
> Arnd Wippermann
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.169 / Virus Database: 270.7.0/1679 - Release Date: 9/18/2008
5:03 PM
