[OpenLayers-Users] WMS layer with different SRS than basemap
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Fri Sep 19 09:47:49 EDT 2008
This is the answer I got from Chris few months ago when I asked for the
same question :
OpenLayers does not support the display of differently projected WMS
>> layers. I'm assuming that in this case, your two different projection
>> strings have the same projection, and that this isn't actually two
>> different projections like OpenLayers tries to helpfully assume it is.
>> If that's the case, then the code to modify is the getFullRequestString
>> function: specifically, doing something like this:
>> OpenLayers.Layer.WMS.prototype.getFullRequestString =
>> function(newParams, altUrl) {
>> var projectionCode = this.projection.toString();
>> this.params.SRS = (projectionCode == "none") ? null :
projectionCode;
>> return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(
>> this, arguments);
this should avoid map projection override of layer's specific projection
Hope that helps
Guillaume
Dejung Gewissler a écrit :
> Hi All-
> I've searched on Nabble for the answer to this to no avail. I know you
> all are busy with the release cycle (!kudos to all that are involved!),
> but I was hoping someone has an easy answer for this problem.
> I've got some WMS services coming from IMS or ArcGIS servers and some
> others coming from GeoServer. Unfortunately ESRI identifies the NJ State
> Plane (us feet) coordinate system as EPSG:102711 and GeoServer uses
> EPSG:3432. ESRI doesn't have a EPSG:3432 and GeoServer doesn't have a
> EPSG:102711!!! I understand that OpenLayers doesn't support raster
> reprojection because it would be nearly impossible to do in a browser,
> etc. My images, however, are fundamentally of the same projection,
> albeit with a different SRS identifier. I just need them laid on top of
> each other.
> I define my map with options {... projection: 'EPSG:102711' ...} and my
> WMS overlays with {... srs: 'EPSG:3432' ...}. The WMS overlays are
> nonetheless being sent with SRS=EPSG:102711. It seems that OL ignores
> the passed-in srs in the layer constructor and defaults to whatever the
> baselayer's projection is. That makes sense in stopping the raster
> reprojection train, but poses a problem in my situation. Is there a way
> to force the SRS change of a WMS overlay?
> Thanks,
> Dejung
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
