[OpenLayers-Users] framedcloud - 2.7rc2
Arnd Wippermann
arnd.wippermann at web.de
Sun Sep 21 16:36:52 EDT 2008
If you prevent the wrapping of text, the popup are shown in IE6 without the
scrollbar. Why it is different between 2.6 and 2.7, and IE and FF, I have no
idea.
body{
white-space:nowrap;
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Don Martin
Gesendet: Sonntag, 21. September 2008 00:13
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] framedcloud - 2.7rc2
the issue is most apparent in IE6 - the extra space with 2.6 isn't a concern
(not showing extra space in .aspx file actually) - it is the wrapping of
rows and the addition of the vertical scroll bar with 2.7rc2.
in FF 2.0 there is some extra space in the lower portion of the box with 2.6
(which isn't a biggie) and appears to function properly with 2.7rc2.
Christopher Schmidt-4 wrote:
> On Sat, Sep 20, 2008 at 12:17:46PM -0700, Don Martin wrote:
>> Hi Eric,
>> here are links to demo issue:
>> ol 2.6 -
>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test26.htm
>> ol 2.7rc2 -
>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test27.htm
>> I can provide the page code instead if that would be more useful.
> So, what I see in:
> * Safari3
> * FF2
> * FF3
> Is that in 2.7, the popups size almost exactly right: there is no
> extra border. In 2.6, the popup is twice as 'tall' as the content.
> Which browser are you using?
>> Don
>> euzuro wrote:
>> > Hi Don,
>> > Thanks for the report. Can you provide a link that shows this (lack
>> > of) functionality?
>> > It is hard to take action given what you've described here.
>> > Cheers,
>> > Erik
>> > On Fri, Sep 12, 2008 at 7:31 PM, Don Martin <donm at alaska.net> wrote:
>> >> we're using framedcloud popups over a gml layer (hover) which
>> >> worked
>> fine
>> >> with 2.6 but doesn't seem to be autosizing (width) with 2.7rc2 -
>> >> it's wrapping rows and adding a vertical scroll bar.
>> >> I was going to try 2.7 to attempt to get zoom-to-extent from the
>> >> GML layer.
>> >> Can I get extents with 2.6?
>> >> suggestions on autosize issue?
>> >> View this message in context:
>> >> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19466263.htm
>> >> l Sent from the OpenLayers Users mailing list archive at
>> >> Nabble.com.
>> >> _______________________________________________
>> >> Users mailing list
>> >> Users at openlayers.org
>> >> http://openlayers.org/mailman/listinfo/users
>> > Users mailing list
>> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19588342.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Christopher Schmidt
> MetaCarta
> Users mailing list
http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19589538.html
Users mailing list
