[OpenLayers-Users] framedcloud - 2.7rc2
Arnd Wippermann arnd.wippermann at web.de
Sun Sep 21 19:43:47 EDT 2008
    <style type="text/css">
body{
    white-space:nowrap;
        #map {
            width: 800px;
            height: 600px;
            border: 1px solid black;
    </style>
It's only thought to show the influence of this css-parameter, because in
this way the parameter works for all text of the htmlside. Perhaps also for
text where the break is wanted.
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Don Martin
Gesendet: Sonntag, 21. September 2008 23:29
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] framedcloud - 2.7rc2
Thanks for the pushback Arnd - where are you inserting the body{} tag?
Arnd Wippermann wrote:
> If you prevent the wrapping of text, the popup are shown in IE6
> without the scrollbar. Why it is different between 2.6 and 2.7, and IE
> and FF, I have no idea.
> body{
>     white-space:nowrap;
> Arnd Wippermann
> [mailto:users-bounces at openlayers.org] Im Auftrag von Don Martin
> Gesendet: Sonntag, 21. September 2008 00:13
> the issue is most apparent in IE6 - the extra space with 2.6 isn't a
> concern (not showing extra space in .aspx file actually) - it is the
> wrapping of rows and the addition of the vertical scroll bar with
> 2.7rc2.
> in FF 2.0 there is some extra space in the lower portion of the box
> with
> 2.6
> (which isn't a biggie) and appears to function properly with 2.7rc2.
> Christopher Schmidt-4 wrote:
>> On Sat, Sep 20, 2008 at 12:17:46PM -0700, Don Martin wrote:
>>> Hi Eric,
>>> here are links to demo issue:
>>> ol 2.6 -
>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test26.htm
>>> ol 2.7rc2 -
>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test27.htm
>>> I can provide the page code instead if that would be more useful.
>> So, what I see in:
>>  * Safari3
>>  * FF2
>>  * FF3
>> Is that in 2.7, the popups size almost exactly right: there is no
>> extra border. In 2.6, the popup is twice as 'tall' as the content.
>> Which browser are you using?
>>> Don
>>> euzuro wrote:
>>> > Hi Don,
>>> > Thanks for the report. Can you provide a link that shows this
>>> > (lack
>>> > of) functionality?
>>> > It is hard to take action given what you've described here.
>>> > Cheers,
>>> > Erik
>>> > On Fri, Sep 12, 2008 at 7:31 PM, Don Martin <donm at alaska.net> wrote:
>>> >> we're using framedcloud popups over a gml layer (hover) which
>>> >> worked
>>> fine
>>> >> with 2.6 but doesn't seem to be autosizing (width) with 2.7rc2 -
>>> >> it's wrapping rows and adding a vertical scroll bar.
>>> >> I was going to try 2.7 to attempt to get zoom-to-extent from the
>>> >> GML layer.
>>> >> Can I get extents with 2.6?
>>> >> suggestions on autosize issue?
>>> >> View this message in context:
>>> >> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19466263.ht
>>> >> m l Sent from the OpenLayers Users mailing list archive at
>>> >> Nabble.com.
>>> >> _______________________________________________
>>> >> Users mailing list
>>> >> Users at openlayers.org
>>> >> http://openlayers.org/mailman/listinfo/users
>>> > Users mailing list
>>> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19588342.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>> Christopher Schmidt
>> MetaCarta
>> Users mailing list
> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19589538.html
> Users mailing list
> Users mailing list
http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19598670.html
Users mailing list
