[OpenLayers-Users] framedcloud - 2.7rc2
Christopher Schmidt
crschmidt at metacarta.com
Mon Sep 22 07:38:00 EDT 2008
On Sun, Sep 21, 2008 at 04:56:51PM -0700, Don Martin wrote:
> OK - gotya - not a solution in my case though thanks.
I'm assuming this is because you have other content in the page. If this
is the case, then a possible solution for you is to do:
.olPopup { white-space:nowrap }
Which will only affect the popup. If this doesn't work for you, can you
explain what the reason is?
-- Chris
> Arnd Wippermann wrote:
> > <style type="text/css">
> > body{
> > white-space:nowrap;
> > #map {
> > width: 800px;
> > height: 600px;
> > border: 1px solid black;
> > </style>
> > It's only thought to show the influence of this css-parameter, because in
> > this way the parameter works for all text of the htmlside. Perhaps also
> > for
> > text where the break is wanted.
> > Arnd Wippermann
> > -----Ursprüngliche Nachricht-----
> > Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> > Auftrag von Don Martin
> > Gesendet: Sonntag, 21. September 2008 23:29
> > An: users at openlayers.org
> > Betreff: Re: [OpenLayers-Users] framedcloud - 2.7rc2
> > Thanks for the pushback Arnd - where are you inserting the body{} tag?
> >> If you prevent the wrapping of text, the popup are shown in IE6
> >> without the scrollbar. Why it is different between 2.6 and 2.7, and IE
> >> and FF, I have no idea.
> >> body{
> >> white-space:nowrap;
> >> Arnd Wippermann
> >> [mailto:users-bounces at openlayers.org] Im Auftrag von Don Martin
> >> Gesendet: Sonntag, 21. September 2008 00:13
> >> the issue is most apparent in IE6 - the extra space with 2.6 isn't a
> >> concern (not showing extra space in .aspx file actually) - it is the
> >> wrapping of rows and the addition of the vertical scroll bar with
> >> 2.7rc2.
> >> in FF 2.0 there is some extra space in the lower portion of the box
> >> with
> >> 2.6
> >> (which isn't a biggie) and appears to function properly with 2.7rc2.
> >> Christopher Schmidt-4 wrote:
> >>> On Sat, Sep 20, 2008 at 12:17:46PM -0700, Don Martin wrote:
> >>>> Hi Eric,
> >>>> here are links to demo issue:
> >>>> ol 2.6 -
> >>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test26.htm
> >>>> ol 2.7rc2 -
> >>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test27.htm
> >>>> I can provide the page code instead if that would be more useful.
> >>> So, what I see in:
> >>> * Safari3
> >>> * FF2
> >>> * FF3
> >>> Is that in 2.7, the popups size almost exactly right: there is no
> >>> extra border. In 2.6, the popup is twice as 'tall' as the content.
> >>> Which browser are you using?
> >>>> Don
> >>>> euzuro wrote:
> >>>> > Hi Don,
> >>>> > Thanks for the report. Can you provide a link that shows this
> >>>> > (lack
> >>>> > of) functionality?
> >>>> > It is hard to take action given what you've described here.
> >>>> > Cheers,
> >>>> > Erik
> >>>> > On Fri, Sep 12, 2008 at 7:31 PM, Don Martin <donm at alaska.net> wrote:
> >>>> >> we're using framedcloud popups over a gml layer (hover) which
> >>>> >> worked
> >>>> fine
> >>>> >> with 2.6 but doesn't seem to be autosizing (width) with 2.7rc2 -
> >>>> >> it's wrapping rows and adding a vertical scroll bar.
> >>>> >> I was going to try 2.7 to attempt to get zoom-to-extent from the
> >>>> >> GML layer.
> >>>> >> Can I get extents with 2.6?
> >>>> >> suggestions on autosize issue?
> >>>> >> View this message in context:
> >>>> >> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19466263.ht
> >>>> >> m l Sent from the OpenLayers Users mailing list archive at
> >>>> >> Nabble.com.
> >>>> >> _______________________________________________
> >>>> >> Users mailing list
> >>>> >> Users at openlayers.org
> >>>> >> http://openlayers.org/mailman/listinfo/users
> >>>> > Users mailing list
> >>>> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19588342.html
> >>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >>>> Users mailing list
> >>> Christopher Schmidt
> >>> MetaCarta
> >>> Users mailing list
> >> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19589538.html
> >> Users mailing list
> >> Users mailing list
> > http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19598670.html
> > Users mailing list
> > Users mailing list
> View this message in context: http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19599836.html
> Users mailing list
Christopher Schmidt
MetaCarta
