[OpenLayers-Users] extent has no properties
Eric Lemoine
eric.c2c at gmail.com
Wed Sep 24 16:37:23 EDT 2008
Hi.
One thing I note, which I'm afraid is unrelated to your issue, is that
you should do:
OpenLayers.Control.prototype.apply(this, [options]);
Instead of:
OpenLayers.Control.prototype.apply(this, arguments);
Eric
2008/9/24, Bas Couwenberg <bascouwenberg at gmail.com>:
> Hello,
> I made a custom control in a separate *.js file which I want to use on
> my WMS layer to select a point there and with a WFS GetFeature request
> retrieve the geometry. The top part of the class looks as followed:
> Select = OpenLayers.Class(OpenLayers.Control, {
> layer: null,
> defaultHandlerOptions: {
> 'single': true,
> 'double': false,
> 'pixelTolerance': 0,
> 'stopSingle': false,
> 'stopDouble': false
> initialize: function(layer,options) {
> this.layer = layer;
> this.handlerOptions = OpenLayers.Util.extend(
> {}, this.defaultHandlerOptions
> OpenLayers.Control.prototype.initialize.apply(
> this, arguments
> this.handler = new OpenLayers.Handler.Click(
> this, {
> 'click': this.trigger
> }, this.handlerOptions
> When I user the 'layer' parameter : *
> var* selectCcontrol = *new* Select(wozSelectLayer, {'displayClass':
> 'olControlSelectFeature'}) ;
> I get the error: extent has no properties
> this.extent = extent.clone();
> Renderer.js (line 98)
> I need the layer in this class and without it the eror doesn't occur. What
> am I doing wrong?
> Best regards,
> Bas Couwenberg
