[OpenLayers-Users] custom layer switcher 1
Adorian Ardelean
mynature at gmail.com
Fri Sep 26 04:24:09 EDT 2008
Hi Brad,
Wow...quite similar to what I aim for: full screen map and floating window
with layer switcher (loaded/adjusted through ajax). I will try to look on
how you control layer visibility and switch base layers through code and if
I have questions I return if you do not mind.
All the best,
Adorian
On Fri, Sep 26, 2008 at 10:06 AM, Brad Spencer <bspencer at cubewerx.com.au>wrote:
> Adorin,
> I have done this quite successfully. You can see it on
> http://demos.numaps.com.au/polypika.html. The DemographicDrapes section is
> based on loading a list of drape definitions from an XML file into a tree.js
> library.
> Works a treat.
> Cheers, Brad….
> *From:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *On Behalf Of *Adorian Ardelean
> *Sent:* Friday, September 26, 2008 3:35 PM
> *To:* users at openlayers.org
> *Subject:* [OpenLayers-Users] custom layer switcher 1
> Hi,
> Perhaps a very simple question: I would like to build a tree-like custom
> layer switcher in a floating div outside of OL map div.
> Could layers visibility (on/off) be controlled through code (base layers
> and the rest)? I did search the Nabble user forum and the examples on OL
> site, but did not find anything on this issue.
> All the best,
> Adorian
> Dr. Adorian Ardelean
> coordinator of myNature Project
> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
> biodiversity-database]
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080926/81a5509f/attachment.html
