[OpenLayers-Users] Transform Vector Layer / Vector Feature
Salvaro
asufsc at gmail.com
Fri Sep 26 06:57:25 EDT 2008
1 - Yes, vector is an array of Feature;
2 - I used the method getGeometry() of the lib gwt-openlayers, it just
returns the attribute geometry (public static native JSObject
getGeometry(JSObject vector) /*-{
return vector.geometry;
}-*/;), and covert the JSObject into a java object.
3 - You are right. And me too when was coding, I typed wrong here, sorry.
Where you saw "vector[i].getGeometry().getBounds().lon()" I wanted to say
exactly vector[i].getGeometry().getBounds().getCenterLonLat().lon()
(getCenterLonLat is the same case of the getGeometry()).
It wasn't return the LonLat because I forgot to covert a Point JSObject in a
Point Java Object, now it's getting the rigth coordinates.
Now I'm trying to find an way to apply the new (converted) coordinates and
"transform" the vectorLayer.
Thanks,
Salvaro.
Christopher Schmidt-2 wrote:
> On Thu, Sep 25, 2008 at 06:02:35AM -0700, Salvaro wrote:
>> * the best ...
>> Don't know why vector[i].getGeometry().getBounds().lon() isn't returning
>> anything.
> 1. I don't know what kind of variable 'vector' is. Assuming it's an
> array of Feature.Vector instances.
> 2. Feature.Vector instances don't have a getGeometry method. They do
> have a geometry property.
> 3. getBounds doesn't have a 'lon' method. It does have a getCenterLonLat
> method.
> vector[i].geometry.getBounds().getCenterLonLat.lon Would probably be
> what I would write. Can you explain what documentatio led you to believe
> either #2 or #3 were right?
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Transform-Vector-Layer---Vector-Feature-tp1115104p1120542.html
