[OpenLayers-Users] Cluster strategy but on the server
Nils Weinander
nils.weinander at curalia.se
Mon Apr 6 05:37:06 EDT 2009
users-request at openlayers.org wrote:
Didrik:
>> I don't know if this is interesting for you but this postgis thread was
>> related to the subject of your mail :
>> http://postgis.refractions.net/pipermail/postgis-users/2005-July/008642.html
Interesting, but as one of the replies said, the clustering
algorithm is iterative in nature, which is hard to do in a
SQL query.
Yves:
> That series of posts is about statistical data clustering as in k-means
> and the like. Give a k-means like algorithm a number of seeds N, it
> will minimize some sum of squares of distances between those seed points
> and the data points and your N clusters will be produced.
> That's not how the clustering strategy in OL is implemented AFAIK. Come
> to think of it a pregenerated set of clusters could be done on distance
> to seed points (e.g. know site locations ?), but that would need to be
> done for every zoom level and even every "tile" in a given zoom level.
Yes, definitely. For my needs I have come up with this:
* A separate table for the cluster features, with columns
for the geometry (a point), a feature count and the scale
(i.e. I store the cluster points for all scales in one
table)
* A view for each scale
"create view cluster_1M as select * from clusters where scale = 1000000"
etc.
* A stored procedure which runs the same clustering algorithm
as OpenLayers.Strategy.Cluster on the original spatial table
and adds the clusters in the cluster table.
* Then I'll set up the layers and scale limits so that the
cluster layer for each scale is dispalyed for that scale
only.
* I'll probably add a trigger on the original spatial table
and add each single new point to the clusters rather than
have to regenerate the whole thing.
The backend is Oracle Spatial (10.2).
Nils Weinander | Systems Designer
Phone +46 (0)8 4100 6456
Mobile +46 (0)709 78 28 37
Curalia AB | www.curalia.se
Hudiksvallsgatan 4, 113 30 Stockholm, Sweden
