[OpenLayers-Users] ZoomToScale
bartvde at osgis.nl
bartvde at osgis.nl
Tue Apr 7 10:00:05 EDT 2009
OpenLayers will snap the nearest resolution.
Try and use fractionalZoom: true on your map options. This will only work
on layers that do not use a set of fixed resolutions, like WMS. It won't
work on Google, TMS etc.
Best regards,
Bart
> Hello list,
> I have another question. I try to realise a textfield where I can type in
> the scale. I want to type a scale in a textbox or so and then the map
> should zoom to this scale.
> I try to make it with the function "zoomToScale" but I don't understand
> it. If I for example set map.zoomToScale(30000) the scale will be set to
> to 50000. If I can trust the "map.addControl(new
> OpenLayers.Control.Scale());"
> I don't know how I can realise it.
> My map options looks like this.
> var options = {
> maxExtent: new OpenLayers.Bounds(555100,129900,678450,245000),
> // maxResolution: 'auto',
> maxScale: '500',
> minScale: '500000',
> units: 'm',
> projection: "EPSG:21781" // Switzerland Projected Coordinate
> System
> I will zoom from 1:500 till 1:500000, but it must be possible to write
> something like 1:30000 to zoom to the scale.
> Can somebody please help me or give me a tip? Perhaps somebody have
> already realise something like this.
> Thank you a lot for your great work.
> Greetings
> Hanno
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und
> Natürliche Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
