[OpenLayers-Users] Issue creating Vector layer with data
Jacolin Yves
yjacolin at free.fr
Thu Apr 9 09:32:33 EDT 2009
Le Thursday 09 April 2009 15:21:11 Christopher Schmidt, vous avez écrit :
> Are you using trunk, or 2.7?
I am using 2.7
> 2.7 doesn't have reprojection support.
Hum, this is strange because I succeed to see my GML layer with the first
method :/ It seems that was du to a cache problem ;)
I added proj4js lib with all my EPSG defs file. Does it explain what it is
working?
> How
> are you testing that there is 'nothing inside'? checking layer.features,
> watching XMLHttpRequest, or just visual inspection?
Using Firebug>DOM, then map.layer[23].features.
My final purpose was to move to GeoJSON format. But my GeoJSON data seems not
good. I tried to use GeoJSON data made from ogr2ogr from a shape file
(railway stations) and it is working. However I can't see the difference
between the files (except that all data of my first GeoJSON file is in one
line).
Hope it is clear,
Y.
Yves Jacolin
Ne demandez pas si vous pouvez contribuer, contribuer ! :)
http://softlibre.gloobe.org
