[OpenLayers-Users] Dynamic size of point using StyleMap
Arnd Wippermann
arnd.wippermann at web.de
Fri Apr 10 05:33:09 EDT 2009
Hi Yves,
Perhaps that's what you search:
http://openlayers.org/pipermail/users/2008-September/007482.html
var style = new OpenLayers.Style(OpenLayers.Util.applyDefaults({
pointRadius: "${scaledSize}"
}, OpenLayers.Feature.Vector.style["default"]), {
context: {
scaledSize: function(feature) {
return feature.layer.map.getResolution() *
feature.attributes.size;
var styleMap = new OpenLayers.StyleMap({"default": style});
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Jacolin Yves
Gesendet: Freitag, 10. April 2009 09:59
An: Users at openlayers.org
Betreff: Re: [OpenLayers-Users] Dynamic size of point using StyleMap
Le Thursday 09 April 2009 18:03:32 Christopher Schmidt, vous avez écrit :
> On Thu, Apr 09, 2009 at 05:49:20PM +0200, Jacolin Yves wrote:
> > Hello,
> > Is it possible to use zoomLevel variable in a symbolizer object in
> > StyleMap? :)
> You can use min and max scale.
> -- Chris
Hi Chris,
Thanks for your answer. May be I wasn't clear on what I want to do or I
don't understand your answer ;) . I wrote a Style object applied to my
vector layer.
I would like that the point radius change for each zoomLevel. i.e. the point
symbol become bigger when zoomLevel is bigger.
Y.
Yves Jacolin
Ne demandez pas si vous pouvez contribuer, contribuer ! :)
http://softlibre.gloobe.org
Users mailing list
http://openlayers.org/mailman/listinfo/users
