[OpenLayers-Users] How to add many(>400) markers to the map?
willson talentp1982 at yahoo.com.cn
Tue Apr 14 06:26:40 EDT 2009
if you were using Geoserver and wms, dynamic symbolizer could help you.
Check the following out:
http://blog.geoserver.org/2008/12/08/dynamic-symbolizers-part-1/
- mika -
willson kirjoitti:
> Hi,
> try to search mailing list for strategies, performance. I have the same problem not solved yet. It looks I will have to render at server site.
> Michal
> Hi everyone, this is the first post on this forum. I have search the problem on the forum, but find no anwser.
> What I need to solve is:  I have more than 400 points need to show on the map, these points query my db every 10 secs, and change their color according to the return value.
> I use the openlayers.layer.marker to implement, but in ie the markers make the map so slow when zooming.
> Then I move to  openlayers.layer.vector, but it's even slower than marker.
> Any suggestion in such "Adding large and dynamically changed markers"  situation?
> hi, render in serverside(may be wms) can improve the performance much, but how to make markers dynamically change color? Any solution?
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
hi,
Yes, I am using geoserver and wms. I have look at the link, but it may be not the answer. Since the data in my db change frequently,  and the marker need to reflect these changes. For example , I have a table, and a column named "kpi", when kpi<0.01, the marker's color is green, else is red. It may be not an "sld" issue.
View this message in context: http://n2.nabble.com/How-to-add-many%28%3E400%29-markers-to-the-map--tp2631715p2632376.html
