[OpenLayers-Users] Problems when using IE7 page zoom feature
Christopher Schmidt
crschmidt at metacarta.com
Wed Apr 15 07:35:14 EDT 2009
On Wed, Apr 15, 2009 at 01:20:39AM -0700, hcan wrote:
> IE7 has a zoom feature.(In IE7, If you look at lower Right Corner, there is a button that let you set the zoom level of your webpage). You can also use CTRL + and CTRL ??? to change the size. Firefox 3 has the same feature Meny->View->Zoom->Zoom in/Zoom out.
> In FF this works fine, but in IE7 the vector overlays are off by a more and more pixels the more you zoom. This is reproducible in the Custom Control Example and Drag Feature Example??? examples.
> Does anyone know if there is a fix for this inIE7?
I've seen this before in both IE7 and Safari; I'm not aware of any fix
or workaround for this.
Regards,
Christopher Schmidt
MetaCarta
