[OpenLayers-Users] Mapserver and Openlayers - Pink Tiles
Christopher Schmidt crschmidt at metacarta.com
Wed Apr 15 10:56:29 EDT 2009
On Wed, Apr 15, 2009 at 08:32:06AM -0600, Alexander Petkov wrote:
> On Wed, Apr 15, 2009 at 5:13 AM, sendeman <martijnsendenspam at gmail.com> wrote:
> > Hi All,
> > I'm new to Openlayers and Mapserver. I want to add a map generated by mapserver to my openlayers map. I have made a simple html-file in my http-root to test the openlayers/mapserver configuration (see below). The map file seems to work. I was able to generate an image with: shp2img -m mymap.map -o mymap.png (see below). When I open the example via localhost, I get a set of pink tiles and the requested map controls. I have added the location of one of the tile-images below. I also added the contents of the Mapserver map-file.
> > I have tried lot's of different ways to spell out the url's in:
> > layer = new OpenLayers.Layer.MapServer("MyMap","../../../bin/mapserv", {map: "../maps/mymap.map"} );
> > , including using absolute paths (c:\...etc). This didn't make any difference.
> > What should I do to get this working?
> At a first glance your mapserv path appears to be incorrect. Where is
> mapserv installed relative to your www root directory? My first guess
> is to try "/bin/mapserv".
Usually /cgi-bin/mapserv, at least on Apache.
http://trac.openlayers.org/wiki/TroubleshootingTips#Pinktiles
Regards,
Christopher Schmidt
MetaCarta
