[OpenLayers-Users] SelectFeature deactivate and VML renderer
Kris Geusebroek
kgeusebroek at xebia.com
Thu Apr 16 02:16:39 EDT 2009
Hi Andreas,
It works.
Thanks for solving this on such short notice.
Is this patch coming with the 2.8 release? Otherwise I have to incorporate it in my own changes.
Cheers Kris
-----Original Message-----
From: Andreas Hocevar [mailto:ahocevar at opengeo.org]
Sent: Wednesday, April 15, 2009 3:20 PM
To: users
Cc: Kris Geusebroek
Subject: Re: [OpenLayers-Users] SelectFeature deactivate and VML renderer
Thanks for reporting this Kris.
See http://trac.openlayers.org/ticket/2048 for a fix.
Regards,
Andreas.
Kris Geusebroek wrote:
> Hi,
> I have a selectFeature control configured for multiple layers. In
> combination with the VML renderer this control shows strange behavior
> when deactivated
> The original layers are redrawn when the overall layer created by the
> selectFeature control is removed from the map. But in IE6 with the VML
> renderer the style of the layers looks like it disappeared.
> After redrawing the layer by zomming in the correct style is applied
> but directly after deactivating the select feature the features look
> like small black lines
> I tracked it down to the moveRoot method of the renderer but can’t
> find the reason why this happens. Same code in firefox with the SVG
> renderer works like a charm.
> It also happens when deactivating the modifyFeature control because
> there the selectFeature control is deactivated internally
> Cheers Kris
> *Kris Geusebroek***
> Consultant
> cid:image001.jpg at 01C7E4CB.5BC48BD0
> Email: kgeusebroek at xebia.com <mailto:kgeusebroek at xebia.com>__
> Tel: +31 (0)35 538 1921
> Fax: +31 (0)35 538 1922
> Mobile: +31 (0)6 30 697 223
> http://www.xebia.com <http://www.xebia.fr/>
> Utrechtseweg 49
> 1213 TL Hilversum
> The Netherlands
> *Xebia Blog !* http://blog.xebia.com/
> *Xebia Podcast!* http://podcast.xebia.com/
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
