[OpenLayers-Users] minScale maxScale on layer
toni hernández tonidelacalle at gmail.com
Thu Apr 16 06:50:55 EDT 2009
hi,
thanks for the answer.
I saw the examples and It looks like minScale and maxScale refer either to
the map object or third part layers.
I tried this code (and several more) on a WMS Layer without any luck.
I mean the layer is always visible.
Also, when I execute getScale the values are quite understandable. (like 107
for the whole territory of spain!!!!).
var catastreLayer = new OpenLayers.Layer.WMS(
                        "Cadastre",
http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx",
                        {layers: 'Catastro', transparent: "true", format:
"image/png"},{tileSize: new  OpenLayers.Size(512,512), singleTile:true,
buffer: 0,minScale: 1/100,maxScale: 1/400}
map.addLayer([catastreLayer]);
2009/4/15 Bill Thoen <bthoen at gisnet.com>
> There's a good description on that subject right here:
> http://trac.openlayers.org/wiki/SettingZoomLevels
> - Bill Thoen
> toni hernández wrote:
>> Does anyone know if it is possible to set the minscale and maxscale on a
>> layer so it shows and hides depending on the scale of the map.
>> If tried to specify minScale:100, maxScale: 5000 (so the layer appears
>> between the two scales) on the layer but the layer is still always visible.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090416/74f6652b/attachment.html
