[OpenLayers-Users] Add layers drawing points
Lucas Eskopinski
eskopinski at gmail.com
Sat Apr 18 15:20:09 EDT 2009
Hi paweluz,
Thanks for you help, working after remove, but do you know why points disappear after I change one specific level zoom?
http://img139.imageshack.us/img139/3610/figura01.png
http://img139.imageshack.us/img139/4426/figura02.png
Thanks.
Lucas Vargas Eskopinski.
Hello
First sorry for may poor English... Well I think I had this same problem when I was learning the WMS stuff. If you have this same problem, which I think you do, the solution is really easy. Remove the 'tilesOrigin' line and that should help you. For example my wms layer looks like this:
stops_8 = new OpenLayers.Layer.WMS(
"Przystanki 8", "http://localhost:8080/geoserver/wms",
layers: 'mgr:stops8',
format: 'image/png',
transparent: 'TRUE'
{ isBaseLayer:false}
And that's enough :)
Good luck... Write if it helps
View this message in context: http://n2.nabble.com/Add-layers-drawing-points-tp2653881p2656886.html
