[OpenLayers-Users] vector popups misaligned after resize & switching of google layers (with fix for Ticket #1797 applied)
Vivien Deparday vivien.deparday at gmail.com
Mon Apr 20 13:52:34 EDT 2009
I encounter a similar behaviour. I've reported it at the end of the
Ticket #1797.
So far, I didn't have time to dig into the code to try to make a clean fix.
I have made a very non-satisfactory makeshift fix which is to add :
this.layer.map.moveTo(this.layer.map.getCenter()); at the line 360 of
the layerswitcher control.
But I will open a new ticket.
Are you vector features misaligned with your baselayer too or is it only
the popup?
Cheers,
Vivien
RFeagin wrote:
> The google resizing and switching layers(Ticket #1797) has been a problem for
> me in one of my applications.  I saw that 2.8 RC1 had a fix for it, so I
> grabbed the google.js from the 2.8 RC1 and tried using it with my 2.7 code.
> I didn't see anything in the changes that looked like it would cause a
> problem.
> Here is what I ran into... I have a point vector layer with hover popups
> using SelectFeature on top of google layers with sphericalMercator = true.
> When I follow the steps listed on the ticket to test the fix, the map now
> resizes correctly (thanks) but the first time I hover over a vector, the
> popup is in the wrong location.  So it looks like the map tiles and vectors
> are realigning after the resize, but the popups aren't.
