[OpenLayers-Users] GetFeatureInfo with loadURL
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Apr 22 14:54:42 EDT 2009
Hi James,
yeah after I hit "Send" I thought just use the function name directly
since there are no extra parameters necessary anymore. So option 1 is
the way to go.
No they are not equivalent, since the second option loses the scope down
the line, and the scope becomes the window object. The only way to keep
the scope would be to use an OpenLayers.Function.bind in between.
Best regards,
Bart
James Leveille wrote:
> Hi Bart,
> First, thanks for the answer.
> Just to let you know that using "i" as my scope works fine with :
> OpenLayers.loadURL ( url, '', i, setHTML );
> but not with :
> OpenLayers.loadURL ( url, '', i, function ( response ) { setHTML ( response ); });
> where I get "[object Window]" instead of the actual value if "i" printed out (as I get with the first declaration).
> Aren't those two declarations equivalent ?
> Again, thanks for your help.
> James
> -----Message d'origine-----
> De : Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
> Envoyé : 22 avril 2009 14:25
> À : James Leveille
> Cc : users at openlayers.org
> Objet : Re: [OpenLayers-Users] GetFeatureInfo with loadURL
> Hi,
> one way is to use i as your scope:
> response); });
> function setHTML ( response)
> alert ( this );
> Best regards,
> Bart
>> Hi,
>> I'm trying to send a getFeatureInfo to all queryable layers.
>> In the "onComplete" function, I would like to be able to "know", for
>> each response, the index of the corresponding layer (the layer index
>> for which the request was sent).
>> But the "index" value in the "onComplete" function is always wrong
>> (seems to be equal to "map.layers.length" value).
>> How can I make sure the index is correctly passed ?
>> Thanks a lot.
>> function findLayerClick ( event )
>> var url;
>> var mouseLoc = map.getLonLatFromPixel ( event.xy );
>> for ( var i = 0; i < map.layers.length; i++ )
>> if ( map.layers[i].queryable )
>> url = map.layers[i].getFullRequestString
>> REQUEST: "GetFeatureInfo",
>> EXCEPTIONS: "application/vnd.ogc.se_xml",
>> BBOX: map.getExtent().toBBOX(),
>> X: event.xy.x,
>> Y: event.xy.y,
>> SRS: "EPSG:32187",
>> INFO_FORMAT: "text/html; charset=ISO-8859-1",
>> QUERY_LAYERS: map.layers[i].params.LAYERS,
>> FEATURE_COUNT: 5,
>> VERSION: "1.1.1",
>> WIDTH: map.size.w,
>> HEIGHT: map.size.h
>> }, map.layers[i].url );
>> OpenLayers.loadURL ( url, '', this, function ( response ) { setHTML (
>> response, i ); });
>> OpenLayers.Event.stop(event);
>> function setHTML ( response, index )
>> alert ( index );
>> ... ... ... // manipulate the result
>> James
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
