[OpenLayers-Users] example for point vector needed
Tim Michelsen timmichelsen at gmx-topmail.de
Wed Apr 22 17:08:01 EDT 2009
Hello,
thanks a lot for the answer.
> http://www.openlayers.org/dev/examples/sundials.html
> has everything you are requesting above.
Thanks for pointing to this file.
I tried to adapt the kml-layer.html (from examples) to use a marker
instead of a kml file. Please see below.
Why does the marker not show a popup on click?
Do you have an idea?
>> My markers shall use lat/lon variables taken from a database (not like
>> the text file example).
> If you take them from a database, you have to format them in some way
> before transmitting to the client. Easiest options include GeoJSON and
> the text file you mentioned. Why don't you like that one?
I want to display a search result.
Using a text or KML file would mean that I would always have to write a
new file to disk when the search gets modified.
I do not yet know GeoJSON. I have to check how to create placemark-like
icons.
Thanks in advance and kind regards,
Timmie
     <script type="text/javascript">
         var lon = 5;
         var lat = 40;
         var zoom = 5;
         var map, layer;
         function init(){
             map = new OpenLayers.Map('map');
             layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
                     "http://labs.metacarta.com/wms/vmap0", {layers:
'basic'} );
             map.addLayer(layer);
             var sundials = new OpenLayers.Layer.Markers("Project Sites");
             map.addLayers(sundials);
             var point  = new
OpenLayers.LonLat(-112.292238941097,36.09520916122063);
             var marker = new OpenLayers.Marker(point);
             sundials.addMarker(marker);
             var sundials = new OpenLayers.Layer.GML("KML",
"kml/point.kml",
                 format: OpenLayers.Format.KML,
                 formatOptions: {
                   extractStyles: true,
                   extractAttributes: true,
                   maxDepth: 2
             map.addLayer(sundials)
             select = new OpenLayers.Control.SelectFeature(sundials);
             sundials.events.on({
                 "featureselected": onFeatureSelect,
                 "featureunselected": onFeatureUnselect
             map.addControl(select);
             select.activate();
             map.zoomToExtent(new
OpenLayers.Bounds(-112.306698,36.017792,-112.03204,36.18087));
         function onPopupClose(evt) {
             select.unselectAll();
         function onFeatureSelect(event) {
             var feature = event.feature;
             // Since KML is user-generated, do naive protection against
             // Javascript.
             var content = "<h2>TEST</h2>" + "some description";
             popup = new OpenLayers.Popup.FramedCloud("chicken",
feature.geometry.getBounds().getCenterLonLat(),
                                      new OpenLayers.Size(100,100),
                                      content,
                                      null, true, onPopupClose);
             feature.popup = popup;
             map.addPopup(popup);
         function onFeatureUnselect(event) {
             if(feature.popup) {
                 map.removePopup(feature.popup);
                 feature.popup.destroy();
                 delete feature.popup;
     </script>
