[OpenLayers-Users] WMC and multi-url in OpenLayers 2.7
Kralidis,Tom [Ontario] Tom.Kralidis at ec.gc.ca
Thu Apr 23 09:25:43 EDT 2009
> -----Original Message-----
> From: Andreas Hocevar [mailto:ahocevar at opengeo.org]
> Sent: Thursday, 23 April 2009 08:55
> To: Kralidis,Tom [Ontario]
> Cc: Jacolin Yves; Users at openlayers.org
> Subject: Re: [OpenLayers-Users] WMC and multi-url in OpenLayers 2.7
> Kralidis,Tom [Ontario] wrote:
> > Correct, WMC 1.1.0 allows one Server element with one
> OnlineResource element.
> > I'm not sure whether OL supports OWS Context, but there you
> can define multiple Servers, and / or multiple OnlineResource
> URLs within a Server element, to handle something like this.
> Currently OpenLayers does not support OWS context, because we
> are uncertain if its state. Tom, can you maybe enlighten us:
> Will OWS context become an OGC standard soon? Where can we
> find the current spec?
> Is the spec already stable?
It's been relatively stable since May 2008.  More info at http://www.ogcnetwork.net/context
I'm hoping to bring this to the table at the OGC meetings in June.  Will keep you updated.
..Tom
> Thanks a lot!
> Andreas.
> > ..Tom
> >> From: users-bounces at openlayers.org
> >> [mailto:users-bounces at openlayers.org] On Behalf Of Jacolin Yves
> >> Sent: Thursday, 23 April 2009 05:33
> >> To: Users at openlayers.org
> >> Hi Andreas,
> >> Thanks for your reply. Indeed it sounds normal among the WMC spec.
> >> Here is the tickets : http://trac.openlayers.org/ticket/2059
> >> I am not sure if I am able to provide a patch as I am not a
> >> javascript developer.
> >> Regards,
> >> Y.
> >> Le Thursday 23 April 2009 11:11:40 Andreas Hocevar, vous
> avez écrit :
> >>> Hi Yves,
> >>> the problem is that there is no concept of multiple server
> >> urls in WMC.
> >>> If you look at the schema for WMC 1.1, you will see that the
> >>> ServerType in the Layer has exactly one occurrence, and the
> >>> OnlineResource inside the ServerType also has exactly one
> >> occurrence.
> >>> So the issue in Format.WMC.v1 is that the content of
> >> layer.url will be
> >>> written to the OnlineResource's xlink attribute, which will
> >> produce an
> >>> invalid value (comma-separated list of urls) if the layer's
> >> url is an
> >>> array. The question is whether we just want to write the
> >> first url, or
> >>> an additional vendor extension value that stores all other urls.
> >>> Anyway, this deserves a ticket. Yves, if you are interested
> >> in getting
> >>> this fixed, we would appreciate if you could create this
> ticket and
> >>> maybe even provide a patch.
> >>> Regards,
> >>> Andreas.
> >>> Jacolin Yves wrote:
> >>>> Hello,
> >>>> I am using WMC OGC service to allow users to print my map with
> >>>> another design. Using multi-URL in OL give something
> like this in
> >>>> the WMC
> >>>> context: <Layer queryable="0" hidden="1">
> >>>>   <Server service="OGC:WMS" version="1.1.1">
> >>>>     <OnlineResource xlink:type="simple"
> >>>> xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="
> >>>> http://www.lpdipro.dev.local/tilecache/tilecache.py,
> >>>> http://www1.lpdipro.dev.local/tilecache/tilecache.py,
> >>>> http://www2.lpdipro.dev.local/tilecache/tilecache.py,
> >>>> http://www3.lpdipro.dev.local/tilecache/tilecache.py"/>
> >>>>   </Server>
> >>>>   <Name>ratp_ligne_metro</Name>
> >>>>   <Title>ratp_ligne_metro</Title>
> >>>> I added space between each url to improve readability.
> >>>> In OL code, after applying the context, the url of tile are:
> >>>> http://www3.lpdipro.dev.local/tilecache/tilecache.py?
> >>>> VERSION=1.1.1&FORMAT=image%2Fjpeg&
> >>>> LAYERS=cadastre&SERVICE=WMS&REQUEST=GetMap&
> >>>> STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&
> SRS=EPSG%3A900913&BBOX=89321.71190000002,6171789.4407,245864.7458000
> >>> 0
> >>>> 003,
> >>>> 6328332.4746& WIDTH=256&HEIGHT=256
> >>>> Again return line and space added for readability.
> >>>> Is it something known and how to correct this? Do I need
> >> to create a
> >>>> bug report, example?
> >>>> Thanks,
> >>>> Y.
> >>>> PS : I am going to test the new OL 2.8RC1 release.
> >> Yves Jacolin
> >> Ne demandez pas si vous pouvez contribuer, contribuer ! :)
> >> http://softlibre.gloobe.org
> >> _______________________________________________
> >> Users mailing list
> >> http://openlayers.org/mailman/listinfo/users
> > Users mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
