[OpenLayers-Users] EPSG:900913 Projection
José Carrizo
c4rrizo at gmail.com
Thu Apr 23 18:44:28 EDT 2009
Hi everybody,
I'm trying to add EPSG:900913 projection definition in geoserver1.5.0 typing
the following line into epsg.properties file:
900913=PROJCS["WGS84 / Google Mercator", GEOGCS["WGS 84", DATUM["World
Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563,
AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich",
0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
AUTHORITY["EPSG","4326"]], PROJECTION["Mercator (1SP)",
AUTHORITY["EPSG","9804"]], PARAMETER["semi_major", 6378137.0],
PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0],
PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0],
PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m",
1.0], AUTHORITY["EPSG","900913"]]
and when I look at srsHelp.do itsn't listed, and console shows the following
message:
WARNING: Issues converting EPSG:900913. No code "EPSG:900913" from authority
"European Petroleum Survey Group" found for object of type
"CoordinateReferenceSystem".
I don't have idea about what's happening :S
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090423/9acb8e3b/attachment.html
