[OpenLayers-Users] How to use OpenLayers requesting WFS
withSpatial Operations
Kris Geusebroek
kgeusebroek at xebia.com
Mon Apr 27 02:11:41 EDT 2009
After having a WFS layer initially loaded you can do something like this to set a different filter and reload the layer:
var newFilter = new OpenLayers.Filter.Comparison(
type: OpenLayers.Filter.Comparison.EQUAL_TO,
property: 'LABEL',
value: label
var combinedFilter=new OpenLayers.Filter.Logical({
type:OpenLayers.Filter.Logical.AND,
filters:[originalFilter,newFilter]
wfsLayer.filter = combinedFilter;
wfsLayer.refresh({force:true});
Hope this helps
Cheers Kris
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Ingo Weinzierl
Sent: Monday, April 27, 2009 7:54 AM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] How to use OpenLayers requesting WFS withSpatial Operations
Hi Myeonghun,
On Saturday 25 April 2009 08:03:24 Myeong Hun Jeong wrote:
> Hi Roald,
> There are two things I want to know.
> 1. How to send WFS requests to server with openlayers? I know the way
> to load WFS layers when I initialize map, but after loading layers, I
> don't know how to request WFS with Spatial Operations in OpenLayers.
I am not quite sure if really got what you mean. But, you should be able to create a new layer and add it to the map on pressing a button. Something like the code below:
// create a button which calls myFunction var button = new OpenLayers.Control.Button({
trigger: myFunction
panel.addControls([button]);
// myFunction which creates a new WMS layer and adds it to the map function myFunction() {
var layer = new OpenLayers.Layer.WMS(
layername,
url,
isBaseLayer: true,
layers: layername
map.addLayers([layer]);
> 2. I also want to know the way to display a WFS layer on my map that
> automatically requests the correct features within the BBOX of the
> viewport?
Have a look at this example:
http://openlayers.org/dev/examples/strategy-bbox.html
> Thanks in advance.
> Best Regrards,
> Myeonghun Jeong.
> 2009/4/25 Roald de Wit <roald.dewit at lisasoft.com>
> > Hi Myeonghun Jeong,
> > Can you explain what you try to do? Do you want to display a WFS
> > layer on your map that automatically requests the correct features
> > within the BBOX of the viewport or do you want to have control over
> > what BBOX you send to the WFS server and send your WFS 'manually'?
> > Maybe it is good to have a look at some examples (type WFS in the
> > search
> > box): [1].
> > Regards, Roald
> > [1] http://www.openlayers.org/dev/examples/
> >> Dear list.
> >> I want to know how to use openlayers when I request WFS with
> >> Spatial Operations.
> >> For example, at GeoServer Demo Request page, I can fin
> >> WFS_getFeatureBBox01.1.url and WFS_getFeatureBBox01.1.xml samples.
> >> So, the request is that
> >>http://localhost:8888/geoserver/wfs?request=GetFeature&version=1.0.0
> >>&typ
> >>eName=topp:states&propertyName=STATE_NAME,PERSONS&BBOX=-75.102613,40
> >>.2125
> >>97,-72.361859,41.512517<
> >>&typ
> >>.2125
> >>97,-72.361859,41.512517>
> >> or
> >> <wfs:GetFeature service="WFS" version="1.1.0"
> >> xmlns:topp="http://www.openplans.org/topp"
> >> xmlns:wfs="http://www.opengis.net/wfs"
> >> xmlns:ogc="http://www.opengis.net/ogc"
> >> xmlns:gml="http://www.opengis.net/gml"
> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> >> xsi:schemaLocation="http://www.opengis.net/wfs
> >> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
> >> <wfs:Query typeName="topp:states">
> >> <wfs:PropertyName>topp:STATE_NAME</wfs:PropertyName>
> >> <wfs:PropertyName>topp:PERSONS</wfs:PropertyName>
> >> <ogc:Filter>
> >> <ogc:BBOX>
> >> <ogc:PropertyName>the_geom</ogc:PropertyName>
> >> <gml:Envelope srsName="
> >> http://www.opengis.net/gml/srs/epsg.xml#4326">
> >> <gml:lowerCorner>-75.102613 40.212597</gml:lowerCorner>
> >> <gml:upperCorner>-72.361859 41.512517</gml:upperCorner>
> >> </gml:Envelope>
> >> </ogc:BBOX>
> >> </ogc:Filter>
> >> </wfs:Query>
> >> </wfs:GetFeature>
> >> But when I use openlayers, how to request thses requests exactly?
> >> For instance, when I request GetFeatureInfo with openlayers.
> >> // support GetFeatureInfo
> >> map.events.register('click', map, function (e) {
> >> document.getElementById('nodelist').innerHTML =
> >> "Loading... please wait...";
> >> var url = map.layers[0].getFullRequestString(
> >> REQUEST: "GetFeatureInfo",
> >> EXCEPTIONS: "application/vnd.ogc.se_xml",
> >> BBOX: map.getExtent().toBBOX(),
> >> X: e.xy.x,
> >> Y: e.xy.y,
> >> INFO_FORMAT: 'text/html',
> >> QUERY_LAYERS: map.layers[0].params.LAYERS,
> >> FEATURE_COUNT: 50,
> >> WIDTH: map.size.w,
> >> HEIGHT: map.size.h
> >> "http://localhost:8888/geoserver/wms"
> >> OpenLayers.loadURL(url, '', this, setHTML, setHTML);
> >> OpenLayers.Event.stop(e);
> >> Please, give me a piece of information.
> >> Best regards,
> >> Myeonghun Jeong.
I hope this was helpful.
Regards, Ingo
Ingo Weinzierl OpenPGP key: 0x2D2E2573
http://www.intevation.de/
Intevation GmbH, Neuer Graben 17, 49074 Osnabrück; AG Osnabrück, HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
