[OpenLayers-Users] Node was not found: code:8 - fixed in 2.6+ ?????
plen
peteralen at earthlink.net
Mon Apr 27 13:28:04 EDT 2009
Hello,
We are using OP v2.5 but will be moving to v2.7 in the next month or so.
Currently (in v2.5) I have been getting the error 'Node was not found" code:
"8' in Firefox (v2.0). The error is triggered when I call:
getFeaturesLayer().addFeatures([.feature]);
My feature is a "new OpenLayers.Feature.Vector(point,null,style);" where I
define the external graphic and size, etc for the point.
I saw two older OL trouble tickets (#1042 and #1178) which reference the
problem, although the error may be called for different operations on the
feature. It looked like there was a fix in OL v2.6, but I am not sure I
understaood that correctly.
So, my question is to find out if the problem I am seeing in v2.5 has indeed
been fixed and when we move to v2.7, all should be well. Or whether it
could still be a problem.
Thanks - Peter
View this message in context: http://n2.nabble.com/Node-was-not-found%3A-code%3A8---fixed-in-2.6%2B-------tp2727381p2727381.html
