[OpenLayers-Users] vector layer with WFS protocol: load
wheninvisible?
bartvde at osgis.nl
bartvde at osgis.nl
Wed Apr 29 09:47:25 EDT 2009
Could this have to do something with allOverlays: true which I am using?
I've changed back the sequence of layers (should be up in 5 minutes) so
it's reproduceable in the following example (the GNIS population is the
WFS layer), switch it off and zoom to max extent you'll see the WFS
request for the whole world going off.
http://dev.openlayers.org/sandbox/bartvde/owscontext/openlayers/examples/owscontext.html
Best regards,
Bart
> It only happens if the WFS layer is the first one in the layers stack, so
> map.layers[0]. I'll try and investigate further.
> Best regards,
> Bart
>> Hey Kris,
>> thanks for your reply. Strangely enough I cannot reproduce it anymore,
>> my
>> sandbox was created off trunk 2 days ago.
>> Best regards,
>> Bart
>>> Hi Bart,
>>> I have the same setup but when layer is created with visibility: false
>>> no requests are made until visibility is changed.
>>> Are you sure you use the last trunk version. I believe there has been
>>> some changes to activate protocol later than originally was done.
>>> Cheers Kris
>>> -----Original Message-----
>>> From: users-bounces at openlayers.org
>>> [mailto:users-bounces at openlayers.org]
>>> On Behalf Of bartvde at osgis.nl
>>> Sent: Wednesday, April 29, 2009 2:26 PM
>>> To: users at openlayers.org
>>> Subject: [OpenLayers-Users] vector layer with WFS protocol: load
>>> wheninvisible?
>>> Hi list,
>>> using trunk I see that a vector layer with a BBOX strategy and a WFS
>>> protocol does request data even if it is not visible in the map.
>>> Is this intentional / by design?
>>> Best regards,
>>> Bart
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
