[OpenLayers-Users] Displaying a popup on mouse over AND a different popup on click.
Adrian Popa adrian_gh.popa at romtelecom.ro
Mon Aug 3 03:54:08 EDT 2009
Hello everyone,
This is sort of a repeat message of "Re: [OpenLayers-Users]
Labels/Tooltips on mouse over a Vector layer" - but with a slightly
different idea.
Problem: I want to display a small div/popup with the marker's name when
the user hovers his mouse over the location, and I want to display a
bigger popup when the user actually clicks on the location.
Current status:
* I can use {hover: true} to register featureselected/featureunselected
when I hover over a marker instead on when I click on the maker.
* I haven't found any events that could differentiate between hover and
click
I'm thinking I could register my select control with hover: true and
allow featureselected to execute the same function for both when I click
on the makrer as well as when I hover over the marker. I would  like to
know if there's any way to find out in the event inside the function if
the user clicked or not his mouse. Depending on this, I would show one
popup or the other.
Something like:
select = new OpenLayers.Control.SelectFeature(markers, {clickout:true,
hover:true});
        markers.events.on({ "featureselected": onMarkerSelect,
"featureunselected": onMarkerUnselect, "visibilitychanged":
onMarkerToggle });
        map.addControl(select);
        select.activate();
function onMarkerSelect(event){
    var feature = event.feature;
    //find out if the user clicked or not
    var clicked = event.*findAWayToSeeIfTheUserClicked()*;
    if(clicked){
       //show larger popup
    else{
       //show smaller popup
Suggestions are welcome.
Thanks,
Adrian
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090803/1e68bd67/attachment.html
