[OpenLayers-Users] also strange vector behavior (obviously I've
messed up)
Christopher Schmidt
crschmidt at metacarta.com
Mon Aug 3 13:54:32 EDT 2009
On Mon, Aug 03, 2009 at 08:35:10PM +0300, Nicholas Efremov-Kendall wrote:
> Hi all,
> Not sure what's going on here, and what/why I'm doing wrong.
> I'm loading successfully a gml layer which isn't displaying in the right
> place
> var topo = new OpenLayers.Layer.GML ("Topography", "data/topo.gml",
> style: {strokeWidth: 1, strokeColor:"#CCCCCC"},
> when I add projection and format criteria, it doesn't display at all, let
> alone in the wrong place, and the auto map.setCenter function doesn't work.
> projection: new OpenLayers.Projection("EPSG:4326"),
> format: OpenLayers.Format.GML,
> Is there anything really obvious that I'm missing? thanks again, in advance
Are you using IE? If so, the trailing ',' after format will fail.
Do you have a debugger/error reporting turned on? Check these things first
for errors.
Otherwise:
http://docs.openlayers.org/help/minimize.html
Regards,
Christopher Schmidt
MetaCarta
