[OpenLayers-Users] Zoom Level and Base Layer problem
Marc Jansen
jansen at terrestris.de
Mon Aug 3 17:58:27 EDT 2009
Hi Raul,
just a guess: JavaScript / OpenLayers is case sensitive, so first you
would need to write:
minExtent: new OpenLayers.Bounds(-75.69927, -4.79079, -75.67719, 4.81273),
maxExtent: new OpenLayers.Bounds(-180,-90,180,90)
Then you could set min- and max extent on the map-object as well, e.g.:
var map = new OpenLayers.Map('map', {
Afterwards you could issue:
map.zoomToExtent( map.getMinExtent() );
To zoom to a specific zoom level use
map.zoomTo( yourZoomLevel );
maybe you only need to set the center of the map and an appropriate
zoomleve like so:
map.setCenter(lonlatObj, zoomlevel);
BTW a map.zoomToMaxExtent would zoom to the extent of whole world.
Regards,
Marc Jansen
Raul David Orozco schrieb:
> Hi. I´m dealing with an issue and I'm out of ideas right now.
> I've a layer created in my own WMS server, this layer is built with
> data from some part of my city of residence, but when I load the layer
> with OL, the zoom level is very far away, because of that my map looks
> like a tiny black dot, so I have to do zoom a lot of times to actually
> see something. I need to know how to set the initial zoom level.
> Here's the code I'm using to create the Layer.
> Layer = new OpenLayers.Layer.WMS( layer.name,
> "http://192.168.1.5:9090/smms/wms.php",
> {'layers': layer.name,
> format: "image/png"},
> { MinExtent: new
> MaxExtent: new
> OpenLayers.Bounds(-180,-90,180,90),
> maxResolution: "auto"});
> "This coordinates (-75.69927, -4.79079, -75.67719, 4.81273) contain
> inside all the graphic I want to show in the initial zoom level ". I
> used ZoomtoMaExtent but I get an error of "bounds is null". Thanks.
> ¡Obtén la mejor experiencia en la web!
> Descarga gratis el nuevo Internet Explorer 8
> http://downloads.yahoo.com/ieak8/?l=e1
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
