[OpenLayers-Users] Using a more readable OpenLayers.js
Andrew Sullivan Cant acant at alumni.uwaterloo.ca
Tue Aug 4 11:38:08 EDT 2009
Adrian,
I saw a similar error when I was attempting to integrate OL into Drupal. I was only experimenting at the time so I have not followed up.
I would be really interested to hear what you find. And I will go back to my own work and see whatelse I can report on the problem that I was seeing.
Andrew
----- Original message -----
> Hello Marc,
> I spoke too soon. If I use that file, I get ~34 errors in Firebug all
> complaining that "OpenLayers.Layer is undefined" in various js files. It
> seems something doesn't load properly.
> I'm using OpenLayers 2.8, stored in /var/www/html/map/openlayers/
> directory on my web server. My page loads it like:
> <script type="text/javascript" src="openlayers/lib/OpenLayers.js"></script>
> Any ideas?
> Adrian
> Marc Jansen wrote:
> > Hi Adrian,
> > assuming you are using a local copy of OpenLayers, you could use
> > OpenLayers-Folder/lib/OpenLayers.js
> > instead of
> > OpenLayers-Folder/OpenLayers.js
> > which would load lots of uncompressed/non-minimized js-files.
> > Regards,
> > Marc
> > Adrian Popa schrieb:
> > > Hello,
> > > I'm running into a problem where firebug says "element doesn't exist"
> > > somewhere in OpenLayers code. I'm having trouble debugging this
> > > issue, because my Openlayers code is pretty compact. What should I
> > > include in to have OpenLayers with a more readable code? Is there an
> > > intermediary file with formatting preserved which I could use
> > > temporarly?
> > > Thanks,
> > > Adrian
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
> Users mailing list
