[OpenLayers-Users] What is the relationship between zoom level
and longitude/latitude
Adrian Popa
adrian_gh.popa at romtelecom.ro
Fri Aug 7 07:57:11 EDT 2009
Thank you all for your help,
I used zoomToExtent and it worked great...
Kenneth Skovhede, GEOGRAF A/S wrote:
> There is a function just for that:
> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.zoomToExtent
> If you need the value, you can call this:
> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.getZoomForExtent
> You can examine the code if you are interested in the inner workings
> of calculating a zoom level from a rectangle.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Adrian Popa skrev:
>> Hello everybody.
>> I'm trying to zoom to view an area for which I have the minimum and
>> maximum longitude/latitude. Basically I would like to zoom in to see
>> a rectangle with known coordinates. I already calculated the center
>> of this rectangle - so that's not a problem - the map centers
>> beautifully to that.
>> The problem is: I have to find out which minimum zoom setting would
>> allow my area to be fully visible - so I need to choose a zoom
>> setting. There must be a relationship between the difference in
>> longitude (or latitude) to a zoom level.
>> I wonder if anyone knows this relationship - or should I determine it
>> empirically.
>> Thank you.
>> By the way, my map is using spherical mercator projection, but my
>> coordinates are in longitude/latitude (although there is no problem
>> in converting them...).
