[OpenLayers-Users] Simple Layer Visibility Problem...
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Aug 7 12:11:26 EDT 2009
check out Firebug and you'll see the error:
visible is not defined
http://www.brianjamesbaldwin.com/Map/
Line 56
Try something like:
function Lakeview() {
  parisoaks.setVisibility(document.forms[0].Lakeview.checked);
Best regards,
Bart
BrianJ wrote:
> Hi Everyone, I'm really excited to have started working with OpenLayers and
> all the frustrations I'm sure to experience.
> I have a real beginner problem here... I'm simply trying to turn a layer on
> or off with a form check button, and it's not working, searched the forum
> and can't seem to solve the problem...
> Thanks
> The full code is located here: http://www.brianjamesbaldwin.com/Map/
> or...
>             var parisoaks = new OpenLayers.Layer.GML("KML", "kml/PO.kml", {
>         			   format: OpenLayers.Format.KML
> 			    map.addLayers([parisoaks]);
> 				parisoaks.setVisibility(false);
> 			  if (visible === true) {
>         parisoaks.setVisibility(true);
>       } else {
> <label>
>    	            <input name="Lakeview" type="checkbox" id="Lakeview"
> value="visible" onclick="Lakeview()" />
>    	          Lakeview</label>
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
