[OpenLayers-Users] centerLayerContainer is setting pixel center to
0, 0
Eric Mckenna
emckenna at phase2technology.com
Fri Aug 7 20:02:16 EDT 2009
I've been through this for two days now and can't get this figured out. I can see why it's happening, but everything I see online about calling Gmap.checkResize() doesn't fix this particular problem.
This bug happens about 90% of the time, the other 10% the map renders correctly and gets the correct center.
For my popup, I'm using the JS Tools overlay.
What my popup and map look like.
http://skitch.com/emackn/b4ue9/offcentermap
Here's my debug output.
http://skitch.com/emackn/b4ues/centerlayercontainer-debug
Here's how I call centerLayerContainer:
function hotspotsLaunchDetails(anchor) {
$.getJSON($(anchor).attr("href"),
function(data) {
$('#hotspot-overlay-map').html('');
hotspotsRenderDetailMap("hotspot-overlay-map", data.hotspot);
var map = Drupal.hotspotsMap['hotspot-overlay-map'];
var lat = Number(data.hotspot.latitude);
var lon = Number(data.hotspot.longitude);
var hotspot = new OpenLayers.LonLat(lon, lat);
debugger;
// I added this here since the map should always be available after rendering.
map.centerLayerContainer(hotspot);
//map.updateSize();
Drupal.hotspotOverlay.load();
return false;
and where I set up my map.
function hotspotsRenderDetailMap(id, config) {
var lat = Number(config.latitude);
var lon = Number(config.longitude);
var zoom = Number(config.zoom);
var image = config.marker;
OpenLayers.ImgPath = config.imgpath;
var map = new OpenLayers.Map(id, {
controls: [
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.ScaleLine(),
new OpenLayers.Control.LayerSwitcher()
// In case something needs to get at this later
if (!Drupal.hotspotsMap) {
Drupal.hotspotsMap = [];
Drupal.hotspotsMap[id] = map;
var google = new OpenLayers.Layer.Google(
"Google Hybrid",
{ type: G_HYBRID_MAP,
numZoomLevels: 18,
map.addLayer(google);
//google.setMapObjectCenter(hotspot, zoom);
if (!map.getCenter()) {
//var epsg4326 = new OpenLayers.Projection("EPSG:4326");
var epsg3785 = new OpenLayers.Projection("EPSG:3785");
//hotspot.transform(epsg4326, map.getProjectionObject());
hotspot.transform(epsg3785, map.getProjectionObject());
map.setCenter(hotspot, zoom);
// MARKERS AND KML
map.setLayerIndex(markers, 100);
map.updateSize();
Eric Mckenna
Software Engineer
Phase2 Technology
direct: 703.548.6050,110
www.phase2technology.com
Web solutions that fit your business.
