[OpenLayers-Users] Problems with IE8 and GeoJSON
Gerhard Dünnebeil Gerhard.Duennebeil at chello.at
Wed Aug 12 01:44:38 EDT 2009
Hi everybody.
Not sure this problem already got discussed, if yes.....please give me a
pointer to it. Otherwise  .....
I try to display a vector layer using a fixed strategy and GeoJSON.
Things work fine under Firefox.
When I test things with IE8, things fail. I run IE8 in default mode, no
special headers or anything set on the web page that holds the map or
elsewhere.
I digged deeper into it and found the following strange behaviour:
When the Layer is about to be drawn, data is fetched from the net and
converted from JSON to java script. This happens in the read method
(GEOjson.js/Line 64, see code excerpt below)
A bit below (line 69) the conversion is done into the variable "obj".
When you look at the "obj" variable at this point it holds an array
named features *but* the feature array has *no* length property.
Otherwise the array is correct with respect to the input data.
In line 108 this feature array is iterated with a reference to the
length property. When IE8 interprets this statement the feature array
suddenly *has* a length property but it is wrong (too big, 3 instead of 2).
As a follow-up error this causes the loop to break via the catch block
when features[2] is accessed and gives back an empty result instead of
the expected.
Is this a known problem?
How to work around it?
thanks for any help and
best regards
Gerhard
Appendix 1, the code mentioned above)
read: function(json, type, filter) {
        type = (type) ? type : "FeatureCollection";
        var results = null;
        var obj = null;
        if (typeof json == "string") {
line 69:            obj = OpenLayers.Format.JSON.prototype.read.apply(this,
                                                              [json,
filter]);
        } else {
            obj = json;
        if(!obj) {
            OpenLayers.Console.error("Bad JSON: " + json);
        } else if(typeof(obj.type) != "string") {
            OpenLayers.Console.error("Bad GeoJSON - no type: " + json);
        } else if(this.isValidType(obj, type)) {
            switch(type) {
                case "Geometry":
                    try {
                        results = this.parseGeometry(obj);
                    } catch(err) {
                        OpenLayers.Console.error(err);
                    break;
                case "Feature":
                    try {
                        results = this.parseFeature(obj);
                        results.type = "Feature";
                    } catch(err) {
                    break;
                case "FeatureCollection":
                    // for type FeatureCollection, we allow input to be
any type
                    results = [];
                    switch(obj.type) {
                        case "Feature":
                            try {
                                results.push(this.parseFeature(obj));
                            } catch(err) {
                                results = null;
                            break;
line 108:                            for(var i=0,
len=obj.features.length; i<len; ++i) {
                                try {
results.push(this.parseFeature(obj.features[i]));
                                } catch(err) {
                                    results = null;
                            break;
                        default:
                            try {
                                var geom = this.parseGeometry(obj);
                                results.push(new
OpenLayers.Feature.Vector(geom));
                            } catch(err) {
                                results = null;
                break;
        return results;
Appendix 2, the JSON data
{ "type" : "FeatureCollection", "features" : [ { "type" : "Feature"
,"geometry": { "type": "Point", "coordinates": [291068,270013] }
,"properties": { "img_url": "icons/green_dot.gif" } }, { "type" :
"Feature" ,"geometry": { "type": "Point", "coordinates": [291069,269967]
} ,"properties": { "img_url": "icons/red_dot.gif" } }, ] }
