[OpenLayers-Users] Is there any way to avoid loading spatial
data when using OpenLayers.Control.GetFeature?
François Van Der Biest
francois.vanderbiest at camptocamp.com
Wed Aug 12 02:43:34 EDT 2009
Why not just use a WMS GetFeatureInfo request for that purpose ?
You should be able to get only the attributes, and no geometry in the response.
Cheers,
F.
On Tue, Aug 11, 2009 at 6:01 PM, Michael
O'Cleirigh<michael.ocleirigh at rivulet.ca> wrote:
> Hello,
> I have a WMS layer containing various polygons that are used to
> subdivide a map. The boundaries run along the street center line and
> rivers, etc. It is a transparent layer sitting on top of google maps.
> When the user clicks on the map I want to use WFS to get the zone number
> of the polygon that contains the clicked point.
> But the problem is that I don't need the geographic detail of the zone.
> I add the zone number into the WMS layer logical filter which toggles
> the polygon visibility.
> Because the performance is slow I want to avoid fetching the spatial
> data as part of the WFS request.
> In the browser I can add a 'propertyName' parameter and this will
> constrain the attributes returned to only include the zone number (i.e.
> to exclude the spatial column). But I can't figure out how to do this
> to a OpenLayers.Protocol.WFS object.
> Does anyone have an example of how I can do this? or do I need to craft
> a custom OpenLayers.Request call?
> Thanks for your help,
> Mike
