[OpenLayers-Users] Selecting multiple features in the same point
Jerome Freyre jerome.freyre at hispeed.ch
Thu Aug 13 07:43:21 EDT 2009
Hi Manuel,
Another way should be the use of the cluster strategy.
If you activate the strategy, all closest points are transform in one
feature called cluster. And the cluster contains points so you can easily
display informations about your points.
http://openlayers.org/dev/examples/strategy-cluster.html
Manuel Albela Miranda wrote:
> Hi everybody!,
> I have one GML layer where some of the points are in the same location, so
> I'm wondering if it's possible to get all the features that are at that
> location when you click on it by using the SelectFeature control or if
> there
> is another way to do that.
> Thank you very much in advance.
> Manu.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Selecting-multiple-features-in-the-same-point-tp3436892p3437344.html
