[OpenLayers-Users] Starting function if layerstatus is changed
Adrian Popa
adrian_gh.popa at romtelecom.ro
Fri Aug 14 09:15:11 EDT 2009
Hello Kai,
Are you trying to turn the layer on/off from outside the Layer Switcher?
Regards,
Adrian
Kai Behncke wrote:
> Hi Adrian, Hi Alexandre,
> thank you for your hints, nevertheless I didn`t get it.
> With "my_layer.visibility" I will get easily the status (true/false),
> but the problem I have is that I don`t know how to get the function setVisibility() (that is called after activatin/deactivating a layer in Control.LayerSwitcher).
> I mean:
> I turn the layer on/off and the function obviously is called.
> But how can I do a request on that?
> Something like:
> if (setVisibility()) {
> alert ("change");
> alert (my_layer.visibility);
> of
> If this.map.events.triggerEvent("visibilitychanged")) {
> Well, I will try on.....
> Best regards, Kai
> -------- Original-Nachricht --------
>> Datum: Fri, 14 Aug 2009 15:37:30 +0300
>> Von: Adrian Popa <adrian_gh.popa at romtelecom.ro>
>> An: Kai Behncke <Kai-Behncke at gmx.de>
>> CC: users at openlayers.org
>> Betreff: Re: [OpenLayers-Users] Starting function if layerstatus is changed
>> Hello Kai,
>> Not sure if this is what you're looking for, but I registered my
>> function to run when the layer changes visibility (is toggled on/off):
>> markers.events.on({ "featureselected": onMarkerSelect,
>> "featureunselected": onMarkerUnselect, *"visibilitychanged":
>> onMarkerToggle* });
>> markers is a Vector layer, but the event should be available for every
>> layer. You can check in your function to see if the layer has been
>> toggled off or on by looking at markers.visibility:
>> *function onMarkerToggle(event) {
>> //do something if visibility becomes true
>> if(markers.visibility == true){
>> alert("This layer just turned visible!");
>> Regards,
>> Adrian
>> Kai Behncke wrote:
>>> Dear users,
>>> I would like to start a function if the layer is on/off.
>>> I tried e.g.
>>> if (this.map.events.triggerEvent("changelayer")){
>>> alert ("here we go");
>>> and
>>> if (my_layer.display()){
>>> ...but so far without success.
>>> Can anybody help please?
>>> Thank you very much, Kai
>> Adrian Popa
>> NOC Division
>> Network Engineer
>> Divizia Centrul National de Operare Retea
>> Departament Transport IP & Metro
>> Compartiment IP Core & Backbone
>> Phone: +40 21 400 3099
Adrian Popa
NOC Division
Network Engineer
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090814/7013c2d9/attachment.html
