[OpenLayers-Users] IE7 Error when adding vector layer
Derek Watling
derek at cmainfo.co.za
Fri Aug 14 09:58:37 EDT 2009
Hi Christopher
Thank you for your reply.
I have a chain of functions/PageMethods that are called starting in the
pageLoad() function as I need other information before the map is
initialised. Each PageMethod waits for the results to be returned and
handled before calling the next one.
However, after much searching and examining information from Microsoft's
forums I have made the following change which seems to have solved the
problem:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"
xmlns:vml="urn:schemas-microsoft-com:vml">
Seems like IE7 wasn't always getting this from the javascript.
Christopher Schmidt-2 wrote:
> Most likely, you are launching your code too early. Make sure you wait
> until the page's "onload" event to start your code.
> Christopher Schmidt
> MetaCarta
View this message in context: http://n2.nabble.com/IE7-Error-when-adding-vector-layer-tp3443849p3445225.html
