[OpenLayers-Users] Anyway to set minimum bounding box?
Marc Jansen jansen at terrestris.de
Sat Aug 15 04:37:48 EDT 2009
Hi Nicholas,
have you set the minExtent and maxExtent properties on the map-Object?
Regards,
Marc
Nicholas Efremov-Kendall schrieb:
> Hi All,
> I'm happily using map.getCenter in a conditional statement
> if( ! map.getCenter() ){
> sites.events.register('loadend', sites,
> function(){map.zoomToExtent(sites.getDataExtent())});
> map.setCenter(null, null);
> which when my layer is loaded centers on the geometry in the map. This
> works great (thanks again, Jan!). The issue I have is when a single
> POI is loaded, the map zooms in all the way and I get the "Mose OSM
> coming soon" tiles which is not aesthetically pleasing.
> I'm going to switch over to a NASA Landsatt, or perhaps an image layer
> as the base, but I still think this will be an issue. Is there anyway
> to constrain this, or to specify a minimum bounding box or zoom level
> to prevent this from happening? The alternative would be to just set
> the function on one of my static GML files, but I like this feature.
> Any suggestions on how to approach this?
> Fulbright Student 2009-2010, Ukraine
> nefremov at artsci.wustl.edu <mailto:nefremov at artsci.wustl.edu>
> c/o Halyna Yerko
> Balzaka 92a, Kv 27
> 02232
> Kyiv, Ukraine
> (mob) +380963576524
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
