[OpenLayers-Users] What's the Best Way to Create Lengends with
OL/MapServer?
Richard Greenwood
richard.greenwood at gmail.com
Sat Aug 15 09:04:25 EDT 2009
I've been using dlegend from the Minnesota DNR. It is based on the
Yahoo YUI. Here's an example:
www2.tetonwyo.org/mapserver/map.php
You can define the legend in the map file's metadata.
Rich
On Sat, Aug 15, 2009 at 5:59 AM, Bill Thoen<bthoen at gisnet.com> wrote:
> Greetings All,
> What's the best way to create legends in an OpenLayers interface over
> MapServer? Is there a way to use the MS HTML legends from a mapfile, or
> do I have to start with GetLegendGraphic calls anyway? What I'd like is
> a Legend / Layer Control from which I could show / hide layers and see
> their current styles -- something like the type 3 legends described in
> the MS docs here:
> http://www.mapserver.org/output/html_legend.html#sample-site-using-the-html-legend.
> But these templates seem to be usable only with MapServer; OpenLayers
> doesn't appear to read a mapfile to that level.
> In the long run, however, what I really want is a Layer Control; one
> that allows the user to change layer order, turn layers on and off,
> change their styles, mark a layer as selectable and/or editable,and
> group layers so that the groups can be moved up or down, made visible or
> hidden, etc. as a group. That, I suppose, is a job for JavaScript or
> something similar, which I can do if that's the best approach, but if
> there's something ready to use out there already, I'd rather not
> re-invent it.
> There always seems to be so many choices when you build your own that
> sometimes I hardly know where to start!
> Thanks,
> - Bill Thoen
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Richard Greenwood
www.greenwoodmap.com
